Mahindra 8560 pops out of reverse
   / Mahindra 8560 pops out of reverse #1
firefighterfox
Spring, Texas
Yanmar 4300
I’m trying to find out why my 8560 started popping out of reverse. All linkages appear to be operating correctly. I tried adjusting it a little to extend the reverse position. That resulted in the forward position popping out as well. I see no cable only steel rods for the linkage. What is supposed to hold the F/R selector in the selected position?
Does that require splitting the tractor?
I had a thought last night about an old CORVAIR transmission I worked on years ago. I think it had a bolt that held a ball bearing and a spring in tension against something in the gear box. Is that technology still used nowadays?
I really don’t want to split this tractor apart again!🫣
   / Mahindra 8560 pops out of reverse #5
Not familiar with your tractor but most are accessible through the top cover where the shift stalk goes in.
2015 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2015 Ford F-350...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2012 NORAM POWER...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
