Mahindra 7520 front axle U-joint
   / Mahindra 7520 front axle U-joint #1
jrchafin
Mahinda 7520
Hi. I have a 7520 4WD that's 10 years old and has about 1000 hours. The right front is making a squeaking noise when rolling. It's worse when it's cold, and will sometimes silence after using for 15 minutes or so. But it's getting worse over the last several months. I'm 99% sure it is the U-joint. There are no grease zerks on it, and I've tried spraying it with lubricant but it had no effect. Any advice? Should I drill into it and force some grease inside to extend the life or just let it squeal until it must be replaced? Seems like it's just running dry and a little lube would go a long way. Doesn't look like an easy repair either. Whole right front will need to be disassembled to get to it. Appreciate input, especially from anybody that has had this problem.
   / Mahindra 7520 front axle U-joint #2
Typically the final drives are fairly easy to take apart- that’s how they are shipped. I’m not familiar with that model though....
If you are asking about drilling a U joint- yes you can drill the end cap. Drill and add grease.....maybe buy a little time. I’ve never seen the flush/flat zerks that you would need in a typical front axle u joint so adding grease won’t be a good seal unless you can find one.
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2015 FREIGHTLINER (A50323)
2015 FREIGHTLINER...
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2016 JLG ECOLIFT...
Horse Hay Feeder (A50515)
Horse Hay Feeder...
