MAHINDRA 7520 4WD front CV/ U JOINTS ..where to find cheaper ones?
   / MAHINDRA 7520 4WD front CV/ U JOINTS ..where to find cheaper ones? #1
fbitz777
Bronze Member
South Western PA
Mahindra 7520 FWD Kubota L4310 M5660 M6060
Ok my 2007 Mahindra 7520 4WD with almost 2000 hrs has bad front cv joints...specifically the cups/needle bearings are shot and that makes loud
bangs when 4WD is engaged
Anyhow my dealer tells me they are $560 per side! The issue is that Mahindra sells the whole assembly (forks, crosses, coupler,...) as a single part
Anyone found cheaper way to do this? Again forks, couplers are not worn out.
Many times I find that Caterpillar parts work on Mahindra (air filters for example)... I have done the same type of job on my CAT backhoe and it was less than $100 per side
   / MAHINDRA 7520 4WD front CV/ U JOINTS ..where to find cheaper ones? #2
I have found it fairly easy to cross mahindra bearings to timken/skf ect on our 2810. The key is the get the actual mfg part number that is on the part itself, not the one assigned by mahindra.
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
2013 Ford F-150 (A50397)
2013 Ford F-150...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2008 CATERPILLAR 140M VHP MOTORGRADER (A51242)
2008 CATERPILLAR...
