mahindra 65302wd shuttle shift
   / mahindra 65302wd shuttle shift #1
bill baldwin
mahindra 6530 2wd shuttle shift
have a problem with pto it stays in gear and will not come out tractor has 373 hrs put new pto switch any one have any suggestions pto came on going down road with mowing machine attached and stay on all the time
   / mahindra 65302wd shuttle shift #2
Do you have a service manual Bill? I have a 3650. There is a PTO control valve. An electrical solenoid in that valve directs hydraulic fluid when the PTO switch is hit and that hydraulic fluid activates the PTO clutch which then causes the PTO shaft to spin. So maybe that solenoid is stuck on? If yours is even set up the same as mine. I'm sorry I can't offer more help. If you can get a service manual it might help to trace the circuit out. Good luck.
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2022 Bobcat T770 Skidloader (RIDE AND DRIVE) (A50774)
2022 Bobcat T770...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
1985 AM General M35A2C 2.5 Ton 6x6 Fire Rescue Truck (A50323)
1985 AM General...
2010 Kubota L3400 (A50120)
2010 Kubota L3400...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
