3-Point Hitch Mahindra 6520 rockshft valve inop.
   / Mahindra 6520 rockshft valve inop. #1
gsmith1986jan
mahindra 6520
My rockshaft valve (3 point hitch) all of a sudden quit working, removed top cover from transmission and found that the valve turned 90 degrees allowing it to slip out from hitting the linkage, tight the valve up and put back together, worked for a few months and quit again. removed all of this again and the problem is else where, changed filters and hyd oils, put back together and worked for a few seconds and quit, my guess its a bad valve or relief stuck open. I have oil going through the 2 bank valves in the back and to the rockshaft valve.
Anyone with this similiar problem ???
   / Mahindra 6520 rockshft valve inop. #2
Not me. I use the 3PH about twice a year. Last time was last month. Nothing wrong then and approaching 600 hours. Main use is the backhoe.
hugs, Brandi
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2018 John Deere 331G Compact Track Loader Skid Steer (A50322)
2018 John Deere...
2 Wheel Wagon / Cart (A50515)
2 Wheel Wagon /...
McKee 504 3pt. Snowblower (A50774)
McKee 504 3pt...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2017 JCB 3TS-8T TELEKSKID SKID STEER (A51242)
2017 JCB 3TS-8T...
