mahindra 6500 vs jd 5303
   / mahindra 6500 vs jd 5303 #1
skiman73
mid georgia
NH TC 45
Am loking at these 2 models for my small produce farm. Will mostly be doing heavy fieldwork, moldboard plowing, discing, subsoiling etc. The jd is $100 less than the 6500 from my local dealers, who are within 2 miles of eachother. They seem pretty close in performance on paper, but the jd has a 3 range tranny, 2 range on the 6500 with the high range seeming like mostly for road use, and fully independent pto versus 2 stage clutch type pto on the 6500. They are both made in India but one is a jd for crying out loud!! This seems like a very easy decision can anyone weigh in with any negative comments on either model or compelling arguments for either machine??
   / mahindra 6500 vs jd 5303 #2
Not sure what you mean about the 2 stage clutch...your post reads to me like you are talking about the 6500...Not so. It has a Independant PTO. If you are really going to use your tractor for significant ground engaging equipment, you need to look to the heaviest/most torque tractor. The 6500's 5th gear (high range, 1st gear), is a good gear for medium bush hogging, box blading, cultivating, etc., however 3 ranges would be great if you intend to do a bunch of tiller work. BobG in VA
Forgot to mention both are 2wd models. I think the 6500 4wd has independent pto, but the 2wd does not, I did a test ride on one yesterday and it has a 2 stage clutch with live but not independent pto. I agree with you on the weight of the thing, I think green is a couple hundred lbs lighter. I have never been a JD guy but I am really leaning toward green on this deal, unless I come across some serious horror stories on the 5303 or my local dealer. Thanks, Dave
   / mahindra 6500 vs jd 5303 #4
If the prices are that close then it's a no-brainer, get the Deere. The biggest reason is because Deere's parts and dealer network is light years ahead of Mahindra's. Independent PTO is another reason. I wouldn't buy a tractor that size without an independent PTO.
2016 Ford Explorer...
3 PT DIRT SCOOP (A51243)
3 PT DIRT SCOOP...
Quick Attach Pallet Forks (A47384)
Quick Attach...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
