Mahindra 6075 won't shift into fwd or Rev
   / Mahindra 6075 won't shift into fwd or Rev #1
speedy223
Crockett
Case DX 45
Shifts all gears but when you put it in fwd with the electric switch nothing same with Rev. Neutral lights up when selected goes off in fwd or Rev
Only 163 light hours. Quit in the middle of mowing. Clutch feels fine.
I am lost on this tractor never broken before where should I start. Yes it is under warranty but it is in a very inconvenient spot on 4th of July weekend. No immediate fix so I would like to figure it out
Any help appreciated
just as a close to this ancient thread: realized i forgot to.
it sheared the link from engine to hydraulic pump shaft and it was replaced under warranty by Mahindra. they said the new part was upgraded.
no problems since.
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
2018 Atlas Copco Pas200HF water pump powered by Duetz diesel engine with Bin Pump (A52377)
2018 Atlas Copco...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53473)
2019 New Holland...
Chevrolet Tahoe SUV (A52377)
Chevrolet Tahoe...
1982 LeeBoy Motor Grader (A53473)
1982 LeeBoy Motor...
TEST YOUR BID BUTTON! (A52706)
TEST YOUR BID...
