Mahindra 6075 cab 4wd- AC quit working, no fan with or without AC, 2019 model
   / Mahindra 6075 cab 4wd- AC quit working, no fan with or without AC, 2019 model #1
Doug Cusick
Mahindra 6075
Mahindra 2019 model 6075 cab tractor AC quit working, no fan with or without AC, charge is good as are all fuses!
   / Mahindra 6075 cab 4wd- AC quit working, no fan with or without AC, 2019 model #2
By "charge" being good I assume you are referring to system refrigerant pressures? That would not have any thing to do with the fan not working.
However, if you checked the system pressure then I would think the clutch is engaging on the compressor. That tells me you have power to the switch panel. So the only things left are the blower switch, fan motor, loose/bad connection or a ground problem at the fan motor.
The switch has multiple contact points for the different fan speeds so if it will not blow at any setting this is unlikely your issue.
The fan motor usually will give an indication it is about to go out so if it has not been making noise or something like that it is likely okay.
I would start by looking at the connections to the fan motor and check for voltage there. Then I would closely inspect the fan motor ground. I think this is where you will find your problem.
Good luck.
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
CATERPILLAR 255 SKID STEER (A52705)
CATERPILLAR 255...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
UNUSED WOLVERINE SBM-12-72W 72" HYD SICKLE MOWER (A54757)
UNUSED WOLVERINE...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
