Mahindra 6010 HST Cab lack of heat
   / Mahindra 6010 HST Cab lack of heat #1
eddiebroadway
STANDISH, ME
1988 KUBOTA B6200DT,2006 KUBOTA 34OODT, 2012 MAHINDRA 6010HST
Thanks to this forum I was able to discover that there might be a Technical Service Bulletin (TYM10-AC/62/10/2012) to remedy the lack of cab heat in my 6010.
I asked my dealer if they would provide the parts so I could do the repair myself and they did. I have a big shop and have been working on equipment for a living and did not want to be without my only means of snow removal.
The repair took a few hours and involves removing the upper radiator hose that had a tee and installing one without, then re routing the oil cooler hose and the cab heater feed hose directly to the thermostat housing.
Now the coolant temp goes up into the normal range instead of staying down on cold and the heat will cook you in the cab!
Next I am looking into the A/C drain hose, heater vent TSB that I also read others have had this done before delivery, that is how I got a hint on this problem. I read every thing I can find on the 5010/6010.
I wish the OEM and or the dealer would contact the owner to provide insight on known problems, it's a huge investment for us regular folks!
Shawn
   / Mahindra 6010 HST Cab lack of heat #2
Thanks for sharing. Nice to have some heat finally!
   / Mahindra 6010 HST Cab lack of heat #3
Hello Shawn, I saw a post you made in 2015 about your 6010HST ... I to have one and was wanting to get some info from you if possible ... Let me know if your still around, Chris
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
EZ-GO D499 Electric Golf Cart (A51694)
EZ-GO D499...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
