Mahindra 6000 Loader
   / Mahindra 6000 Loader #1
tfan101
camden,tn
2004 Mahindra 6000
Does anyone know if there's anyway I can make a ML 264 loader work with my 2004 Mahindra 6000 2wd? It calls for a ML 260 but I've found a very good deal on the ML 264. Thanks
   / Mahindra 6000 Loader #2
Have you taken measurements? It seems to me if it will work depends upon how it will sit on your tractor. There are only two attachment points to consider.
I haven't, just went to the parts website and the mounting brackets look different.
   / Mahindra 6000 Loader #4
The ML264 is build by KMW for the 5500 and 6500 4 wheel drive. It is heavier duty and made higher for clearing the front wheels. The ML260 has been manufactured by Buhler and GB and is designed for 2WD 4500, 5500 and 6500's. The mounting at the front and mid-section of the tractor should be the same but the braces running back under the rear axle I think will be different. It might be easy to alter it to fit but it maybe far more loader than the 2WD tractor can handle.
   / Mahindra 6000 Loader #5
the ML264 came on the 6000 4WD in '02 as well. BobG in VA
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
2011 Nissan Frontier Pickup Truck (A50860)
2011 Nissan...
2 Vintage Metal Signs (A48082)
2 Vintage Metal...
2014 International DuraStar 4300 Terex BT2047 47ft Crane Truck (A48081)
2014 International...
Excavator Bucket (A49461)
Excavator Bucket...
2008 Ram 3500 4x4 Crew Cab Pickup Truck (A48081)
2008 Ram 3500 4x4...
