Mahindra 6000 4WD will not start. NO POWER
   / Mahindra 6000 4WD will not start. NO POWER #1
Oorah
Luther, Oklahoma
Mahindra 6000 '00' Series 4WD
I have been clearing large trees from my wooded areas. A couple days ago when I came back from lunch the tractor would not start. When I turn the starter switch there is no power to the dash or injector heater. The starter doesn't click or turn. The battery is charged and I replaced the starter relay switch.
   / Mahindra 6000 4WD will not start. NO POWER #2
Have you accidentally engaged the PTO lever? Blown master fuse? Tight connections on battery? Check that dead-man switch(if you have one) is working and all wires are connected there. I'm sure others will provide additional checks.
   / Mahindra 6000 4WD will not start. NO POWER #3
Check battery connections at battery as well as the main ground (usually tied to the frame somewhere close).
   / Mahindra 6000 4WD will not start. NO POWER #4
Im guessing you have a sensor switch that detects whether your range selector is in neutral. On my 7520 the wires to the switch are exposed underneath and can get pulled from the switch by brush. Maybe this is your problem.
larry
2023 ROAD FMAX216 40FT GOOSNECK FLATBED TRAILER (A50505)
2023 ROAD FMAX216...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A50397)
2021 John Deere...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
2017 Bobcat E85 Midi Excavator (A49346)
2017 Bobcat E85...
2022 Club Car...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A50505)
2020 FREIGHTLINER...
