Mahindra 575DI
   / Mahindra 575DI #1
freedy
Hi, can anyone help me with rear hydraulic remotes for a Mahindra 575DI?
   / Mahindra 575DI
Does the 575DI have a two speed PTO 540/1000 and can you add rear hydraulic remotes?
   / Mahindra 575DI #4
I have a 485DI and it only has the 540 pto. I don't see why you couldn't add remotes.
   / Mahindra 575DI #5
F350,
With all do respect, the 485DI DOES HAVE 540/1000 rpm pto. Look on the bottom left side of the transmission. There is a lever with a knob (thats gotta be "pulled out" in order to move). Also, there is CRPTO and 540/1000 engraved on the housing.
Travis R
   / Mahindra 575DI #6
Travis, I stand corrected. I was thinking in terms of the PTO lever that engages the PTO. You are correct there is a lever on the right in front of the clutch pedal that allows you to go from 540 to 1000 PTO speed.
My apologies freedy.....
UNUSED CFG INDUSTRIAL SSECAG-Y AUGER BITS (A51244)
UNUSED CFG...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52128)
Adams Load Out...
UNUSED JCT QUICK ATTACH 72" HYD 4N1 COMBO BUCKET (A51244)
UNUSED JCT QUICK...
2020 CATERPILLAR 299D3 SKID STEER (A51242)
2020 CATERPILLAR...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
