mahindra 575 hydraulic orifice filter and suction strainer
   / mahindra 575 hydraulic orifice filter and suction strainer #1
larneu1
where are the above two items located and how do you remove, replace or clean?
   / mahindra 575 hydraulic orifice filter and suction strainer #2
The strainer is a pipe that's going by your right foot and into the front of the lift housing.... you will see a small rubber boot on top of the shifter housing connecting the strainer and the main suction line.
   / mahindra 575 hydraulic orifice filter and suction strainer #3
There are no records listing something called the orifice filter..
ok. thanks. the orifice filter was mentioned in the operators manual. thanks for info on strainer.
1000 gal Poly Tank (A50515)
1000 gal Poly Tank...
UNUSED AGT ATK-B1000 CARLIFT (A51244)
UNUSED AGT...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2017 BOMAG BW145D SMOOTH DRUM ROLLER (A51242)
2017 BOMAG BW145D...
UNUSED FUTURE MINI EXCAVATOR HYD HEDGE TRIMMER (A51244)
UNUSED FUTURE MINI...
JOHN DEERE 3 BOTTOM PLOW (A51243)
JOHN DEERE 3...
