Mahindra 5525 instruments not working
   / Mahindra 5525 instruments not working #1
simon47
Mahindra 5525
I've just joined this forum to get some help with this problem, which I see is a fairly common issue with Mahindra tractors.
The tractor in question belongs to my gliding club and is used for maintaining 30 acres of grass runways. The fuel gauge, temperature gauge, tachometer and the digital hour meter all do not work. The oil pressure and ignition warning lights both work as do the various other indicator lights.
I've driven this tractor for over 40 hours in the last two years and I've never seen the gauges work, although I have been told that other drivers have seen them occasionally work. A couple of years ago, the instrument cluster was opened up and heat-shrink tubing was applied to the stop posts.
We are planning to open the instrument cluster up again and have another look. I would appreciate any tips.
The wiring diagram in the manual is not terribly useful since it is only schematic and a very odd thing is there is no indication on the diagram of a wire related to the tachometer, nor is there any RPM sensor shown. However looking at the wiring for the temperature an oil pressure gauges, I suspect it might be a ground issue.
Does anyone have access to an actual wiring diagram instead of the useless schematic?
The tractor is quite often left out in the open so I suspect that might be part of the problem.
   / Mahindra 5525 instruments not working #2
Yah you have the same problem you had before- wet connections that corroded and are now bad connections. With so much not working dollars to donuts it’s a ground issue. Any manual won’t really help- it’s good old fashion diagnosis that’s needed.
8' Agritek 3Pt Grader (A50515)
8' Agritek 3Pt...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2016 GEHL RS5-19 TELESCOPIC FORKLIFT (A51242)
2016 GEHL RS5-19...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
UNUSED 2025 INDUSTRIAS AMERICA 7014 DUMP TRL (A51243)
UNUSED 2025...
