Mahindra 5525 Hydraulics Sluggish
   / Mahindra 5525 Hydraulics Sluggish #1
truck57
mahindra 5525
All Hydraulics are sluggish front loader and the 3pt. Filter and oil was changed about 2 months ago, just use it a couple weeks ago to move roll of hay.
Just today dropped the roll fork put on auger, the Hydraulics went sluggish
It a Mahindra 5525 2007
   / Mahindra 5525 Hydraulics Sluggish #2
Check your QD fittings, might not have complete flow, or blocked flow. Remove the QD's if you have to, If bad, they will block or reduce flow.
Is the flow from the FEL going through a remote valve?
   / Mahindra 5525 Hydraulics Sluggish #3
Install a hyd gage and test the pressure.
Unhook all QD still have problem in all hydraulics.
I will check with parts store to see if they have a pressure tester.
Sure hope its not pump, if so I will not be happy with my Mahindra less that 500 hrs
thx for the info will try to keep you posted
   / Mahindra 5525 Hydraulics Sluggish #5
Under the seat there's a hand valve (the isolator valve) that controls the speed of the 3pt hitch and locks the 3pt in position when transporting implements long distances. Is it open all the way? Don't know if this will help, but I'd check it anyway.
If it's the hydraulic pump, at least it's mounted on the front of the engine where it's easy to service/replace. My MF135 has the pump buried inside the rear end hydraulics case. A bear to work on.
BTW: my big tractor is a 2008 Mahindra 5525.
   / Mahindra 5525 Hydraulics Sluggish #6
When you get the hyd gage, if you want a permanent connection, just tee it in to the IN port of the FEL valve.
Whenever you use anything hyd, the pressure will be reflected on the gage. Use the FEL levers and max out the cyl and read the pressure. That will tell you if you have pressure, and the FEL relief psi setting.
Then raise the 3pt, max it out, and read the pressure. That is the relief setting on the 3pt. If things are not right, you begin trouble shooting. Hyd tank full, is pump turning, etc.
well finnialy found the problem
a very small pin hole in the intake line was causing it to suck air so small it didnt leak hyd fuild now I just have to put it all back together
once again thank you all for the advice and ideas
   / Mahindra 5525 Hydraulics Sluggish #8
You did not tell us there were air bubbles in the hyd fluid.
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
CATERPILLAR 308CR EXCAVATOR (A51242)
CATERPILLAR 308CR...
UNUSED FUTURE FT-E48 ELECTRIC BICYCLE (A51244)
UNUSED FUTURE...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 KIA Cadenza (A50324)
2015 KIA Cadenza...
