Mahindra 5500 4wd steering cylinder removal
   / Mahindra 5500 4wd steering cylinder removal #1
kmart
Mechanicsburg, MS
Mahindra 5500 4WD
In need of some help, I'm trying to remove my steering cylinder from my 5500 & I can't figure out how to remove the pin that is holding the cylinder on the inside towards the center of the front axle. It looks like a allen head screw is holding the pin but I don't have any allen wrench that will fit. Is this an allen screw?
   / Mahindra 5500 4wd steering cylinder removal #3
That is what it looks like from the picture. Try to tap lightly first see if it moves.
   / Mahindra 5500 4wd steering cylinder removal #4
PM me
I have a owner manual off the Mahindra website before it went down that might help
   / Mahindra 5500 4wd steering cylinder removal #5
Very old thread but thought I would reply anyway.
Yesterday I was having exactly the same issue on a 6500 4WD.
My solution was to simply take an appropriately sized drift and drive the roll pin all the way through.
The next issue is that to get the larger pin out your would want to drive it down but there is no way to get above it to do that. So I just drove it straight up and out.
Both of the above completed without issue after an overnight set after blowing it al lclean and giving it a good soak with Penetrating Blaster.
Now to get the cylinder rebuilt...
My only remaining worry is it seems like it is going to be a little difficult to get all the holes aligned properly to get that retaining roll pin back in there. No way to really grab the large pig to twist it to alignment and no way to really tap it downwards if you drive it too far in. I guess slow and steady with a tapered spud to align the holes.
-S
2015 International ProStar Truck, VIN # 3HSDJSNRXFN563873 (A51572)
2015 International...
TRUCKING INFO (A50775)
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
