3-Point Hitch Mahindra 5035 Bush Hog Cutter Question
   / Mahindra 5035 Bush Hog Cutter Question #1
jbwalls
Mahindra 5035
Gentlemen.
I have a Mahindra 5035. This tractor has (according to the spec sheet) 43 HP at the PTO.
I am looking to up size on my rotary cutter. I currently have a 6 ft that my tractor handles easily, but it is light weight and a regular POS.
So i am looking to up size and get a better quality cutter. I am cutting about 40 acres of pasture land.
I am looking at a Bush hog 2308 3 point cutter. This cutter's specs call for 45 HP.
My question is this. Will my tractor handle this or is it going to be too large? I understand i can go with a pull behind or a semi pull behind and i can probably do those with my tractor.
Thanks for advice!
   / Mahindra 5035 Bush Hog Cutter Question #2
See my response in your other thread
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
Fifth wheel multi use trailer. (A52128)
Fifth wheel multi...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
1041 (A50459)
1041 (A50459)
Case IH 7120 Combine (A50514)
Case IH 7120...
