MAHINDRA 5010 STARTS BUT DOESN'T MOVE
   / MAHINDRA 5010 STARTS BUT DOESN'T MOVE #1
Richardwillis
North Augusta, SC
Mahindra5010
I own a 2011 Mahindra 5010 and have had good service until this past weekend. I had been bush hogging in the afternoon and turned the tractor off. When I went back to crank it to move to the shed, it started just fine, but would not move. Everything else seems to be working as it is supposed to. It seems to go from 2wd to 4wd and back as it should and when I change the gears it acts like it wants to go, but doesn't. Has anyone got suggestions? This one has me stumped. Rich
   / MAHINDRA 5010 STARTS BUT DOESN'T MOVE #2
Not to be a SA but is the E Brake on?
   / MAHINDRA 5010 STARTS BUT DOESN'T MOVE #3
Is it a gear drive or HST?
   / MAHINDRA 5010 STARTS BUT DOESN'T MOVE #6
How about range selector?
Do hydraulics function?
Does engine change sound when it tries to go?
   / MAHINDRA 5010 STARTS BUT DOESN'T MOVE #7
What do you mean by it " acts like it wants to go"? Does the tractor inch forward? Inch backward in reverse? Budge at all? Does it change speed or sound? If you were to try to tow it, will it roll? It lists a single plate dry clutch for your tractor, do you ride the clutch at all? Even rest your foot on it while using it?
When I called the dealership, I was told that it could be the clutch. I found that if I put in low, I could inch it forward and reverse, but that is the only way I could get it to move. I managed to get it on my trailer to take it to the dealership, but I'm just irritated because it only has 160 hrs on it. I don't put my foot on the clutch at all because they stressed that when I purchased it. Someone told me today that he had been told that Mahindra had been having problems with their clutches. Has anyone else heard this?
   / MAHINDRA 5010 STARTS BUT DOESN'T MOVE #9
I'd imagine since most people like to vent about problems, this being the largest forum of this type on the web, there'd be other instances showing up if there was much of a widespread problem. Before taking what was said to heart, I'd identify this someone's someone that said there was an ongoing clutch issue and determine if they have an actual inside line on Mahindra's warranty service details or if they're just typical "good old boys" "shooting the breeze"... It may just be an instance of a fella that knew of a couple Mahindras that had clutch service done and assumed there is an issue when perhaps the others he knows of were all high hours and/or poor operators and he just didn't have all the details. Many details get lost "in the grapevine" when someone says that someone said... There are a few Mahindra dealers that are members here, perhaps one of them could chime in on this with first hand knowledge such as how many 5010s they've sold versus how many have needed service...
I'd also think at 160 hours, you would have had a hard time ruining the clutch even if that was your goal... How many hours did it have when you took possession? Possible someone broke something on the lot in a test (read that as "doing dumb things on pavement") and with you babying it, it took this long to "let go"?
I'd bet once they get into it they find something either didn't go together properly at assembly or some part wasn't quite up to par. Either way I think they should get you fixed up fast. Let us know what they find too.
Best of luck!
   / MAHINDRA 5010 STARTS BUT DOESN'T MOVE #10
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
John Deere 250 Skidloader (RUNS) (A50774)
John Deere 250...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
Hester 1206 10' V Disc (A50121)
Hester 1206 10' V...
2018 CHEVROLET 2500 SILVERADO (A52472)
2018 CHEVROLET...
