Mahindra 5010 fuel leak from vent tube
   / Mahindra 5010 fuel leak from vent tube #1
DutchHenryBrown
Platinum Member
Tombstone, AT
Mahindra 5010
I hope the picture is clear enough, when tractor is running I have fuel leaking from this vent tube on top of valve shut off. It's leaking enough that I can smell it when in the cab. I only have the owners manual which shows nothing, is this normal?
   / Mahindra 5010 fuel leak from vent tube #2
Most of the time you correct that by taking those two small screws out that hold the shut off valve in and reposition the rubber seal under there. It seems to get stuck to the valve and when you turn it, the rubber distorts.
Thanks OGT, I'll give that a try.
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2024 JOHN DEERE FC 10 R LOT IDENTIFIER 79 (A53084)
2024 JOHN DEERE FC...
2007 Dodge 3500, 6.7 Cummins, Automatic (A52384)
2007 Dodge 3500...
2014 FREIGHTLINER BUSINESS CLASS M2 SERVICE TRUCK (A51247)
2014 FREIGHTLINER...
