farmboyhull
Bronze Member
- Joined
- Jun 16, 2008
- Messages
- 55
Good morning gents, hope snow removal in the NE is working for everyone!
I've got a 4530 that's been working fine, recently. I had some rough starts a few weeks ago, so I've been plugging it in overnight for the last few starts. I can't tell you if this issue started at exactly the same time that I've been plugging in, but it's been close.
THe last few starts gave me a click when I turned the key to start (after glowing). One click. When I turned the key back, and then tried again it would turn over and run fine. Exhaust looked a little blue, but I'm not sure if it was any different than every other cold start. Plus, I added some anti-gel stuff recently.
This morning, I got no clicks and no starts. Glowed fine (a quicker glow than normal because it was plugged in), lights came on, etc. But when the key turns, nothing happens.
SOme extra info - I disconnected a couple things summer of 2012 and it's been running like that since then. Both were alarm things, as I recall. One piece is straight up disconnected (when I reconnected it this morning, I could hear a steady click under the dash, almost like the the clicking of a turn signal), and the other I had to patch. I had a piece of wire connecting each outside socket to each other. It's one of those 4 way blade type receivers - the black piece that used to connect got fried, so instead of getting anew one I just put the wire in - it's been great for a year and a half. It's right near my feet, and I have to be careful of it, and I figured I might have jostled it with the snow and all, but externally it looks fine and moving the wire around didn't do diddly.
When it didn't start this morning it was as if the shifter wasn't in neutral, the pto was on, or that wire was disengaged. It had that "I'm not starting because you broke something" kind of finality.
So. Any places to start? I probably won't be able (willing really. I'm at the point in my life where I'd rather pay someone to fix it) to do any fuel work, and my electrical skills are miserable. I do have some sort of helpful electrical tester somewhere, which could probably help. I'm just hoping someone will have the simple fix. But, isn't that what we always hope?
To top it off, both side panels and the hood are refusing to open, but I'll get in there if need be.
Calgon. Seriously.
Thanks.
This thread is in the Mahindra area as well, but figured this might get me more help, here. Feel free to respond to either.
Calgon. Seriously.
Thanks.
