Mahindra 4500 4WD steering problems. HELP
   / Mahindra 4500 4WD steering problems. HELP #1
justabeater37
IA
Mahindra 4500
I was pushing snow today when suddenly the steering wheel became comletely worthless. It spins freely as if it sheared a pin or the like. It has hydraulic oil in the reservoir, the wheels when lifted by the loader will turn very minimally about 1/2-3/4 inch on the steering cylinder. I can not find anything obstructing the steering linkage and it is very free for the minimal travel that I have. Need this fixed ASAP, so looking for ideas before I tear into it in the below zero barn. Seals? HSU? does anyone have a blown apart picture of the HSU so I even know what I am getting into? Thanks, Doug
   / Mahindra 4500 4WD steering problems. HELP #3
Wish I could offer some valuable help. I looked at the online parts diagrams (no HSU breakdown) and can't see anything obvious that would cause this problem other than little/no pressure from pump, blown cylinder seals or bad orbital valve (HSU). I see there is a seal kit for the HSU and that they offered 2 different HSU's on the 4500. I don't know what brand your valve is but I found some threads showing the guts from an Eaton valve Need help rebuilding eaton steering valve and a Danfoss valve Tractor parts and attachments: Disassembly and assembly the Orbitrol steering unit (125/160cm) and a ? brand valve Tractor parts and attachments: Disassembly and assembly the Orbitrol steering unit (80/240cm) . Most orbital valves look basically similar from the outside, hopefully they are generally similar in construction and these diagrams hejp with the Mahindra valve. Wish I could offer more help.
   / Mahindra 4500 4WD steering problems. HELP #4
Try the Mahindra Forum.
Several Mahindra Dealers lurking around there might could help :)
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
International 806 2wd Tractor (A52128)
International 806...
2019 CASCADE DM0B1300 HYD BALE CLAMP (A51243)
2019 CASCADE...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
(5) Rolls of Barb Wire (A50515)
(5) Rolls of Barb...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
