Oil & Fuel Mahindra 4110
   / Mahindra 4110 #2
To check the front axle gear oil (90w) unscrew the cap on top of the axle on the left side, inbetween the wheel and the engine. The level is supposed to be 1/2 way up the axle you see inside - you'll need to use a flashlight to look down inside. I usually just cover the axle with 90w - easier to see and a little extra won't hurt a thing. If you want to check the trans/hydraulic oil, there is a dipstick on top of the rear axle housing on the left side.
   / Mahindra 4110 #3
There is a dipstick just on the left axel housing in the rear of the tractor, front end has a dip stick also.
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
1270 (A50490)
1270 (A50490)
KUBOTA SVL97-2 SKID STEER (A51242)
KUBOTA SVL97-2...
80in HD Tooth Bucket with Side Cutters (A52128)
80in HD Tooth...
2014 INTERNATIONAL LF687(INOPERABLE) (A50854)
2014 INTERNATIONAL...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
