mzat
I have a 2003 Mahindra 4110 with about 850 hours on it. I've owned it since new and the hours have been easy, mostly field mowing. I have a question concerning the clutch. While field mowing, I went to back up into some tall brush and while releasing the clutch (pedal less than half down) the clutch fully engaged and the pedal no longer worked. I had to turn off the engine to stop it. While it was off, I was able to get it into neutral. The clutch pedal has full movement and feels no different than normal but it no longer operates the clutch. Without opening up the tractor, I check all external linkage, joints, pins; everything look good. What would cause the clutch to stay engaged? It seems to me like it would be some type of return spring. Any ideas would be appreciated.
