Traction Mahindra 4110 4wd won't engage
   / Mahindra 4110 4wd won't engage #1
ranchita
Ranchita, ca
Mahindra 4110
4wheel drive lever moves but does not engage front axle through transfer case. Has anyone had this issue and is there a shear pin that could be broken?
   / Mahindra 4110 4wd won't engage #2
Good chance it's the shift fork, I've replaced mine a couple of times over the years. Worst case scenario is the gear or shaft is bad inside the trans - mine was once, it was the rear bearing on the 4wd shaft inside and required a rear split of the tractor for a bearing that cost me less than $4.00 at NAPA. The shift fork is a very simple repair. Drain the trans. fluid and remove the cover w/fork from side of trans to inspect. You can see the gear/shaft inside and check the fork for bending and/or wear. The forks aren't that expensive, I get mine from Galen at LaWall's who participates here.
Thanks for the tips. I pull that plate and have a look.
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
RoGator 844 sprayer (A50490)
RoGator 844...
