Mahindra 4025
   / Mahindra 4025 #1
reb79
2013 Mahindra 4025
I have a 2013 Mahindra Model 4025 2WD tractor. Almost without failure....if I run the tractor for say 45 minutes to an hour......it starts losing power....(starving for fuel....seems the same)....Gradually getting worse & worse. To the point it's smoking a little & barely moving along & trying to throttle up is pointless....won't do it. I shut it off, open the bleed screw on the fuel filter.....& start manually pumping up & down on the primer button. Initially....no fuel, just air. Gradually....fuel starts to come out. I keep doing this until good fuel flow. Put all back together, start the tractor & I'm good for another hour or so.
So....anone with any ideas on why I need to continually repeat this. There only 180 hours on the tractor.
   / Mahindra 4025 #2
You may not have a lot of hours on the tractor but you have a few years. If you have a vented fuel tank cap the vent may be plugged. You may also have crud inside the tank at the outlet location. It sounds like you're on the right track.
2016 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2016 VOLVO VNL...
2018 FORD EXPEDITION (A51406)
2018 FORD...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
GORMAN RUPP 4 TRANSFER PUMP (A50854)
GORMAN RUPP 4...
2012 International Semi Truck (A50323)
2012 International...
2015 WESTERN STAR 4900 SF (A50854)
2015 WESTERN STAR...
