Flat Proofing Mahindra 4025 left Front rim broke in half
   / Mahindra 4025 left Front rim broke in half #1
raysmithtx
Fort worth, texas
Mahindra 4025 and a Bobcat E35 excavator
While brush hogging today I thought I had fell in a hole but it turned out the front left wheel had cracked in half (not vertically but completely around the rim). I can see what appears to be a long time rusting crack where it fell apart. I can replace the wheel and tire but the one that came of is filled with a heavy solid of some kind. The solid fill material is black and pretty darn heavy. It's definitely not foam.
So my question is "What is that stuff that is/was inside the tire?" and my next question is can I fill the tire with whatever that stuff is when the new wheel and tire arrive?
I've learned a lot here. I don't post much but I do read a lot.
Thanks.
   / Mahindra 4025 left Front rim broke in half #2
Sound's like it is foam filled. Are you the original owner?
A long time ago I helped a buddy cut a ff tire off the rim and iirc it was also black.
   / Mahindra 4025 left Front rim broke in half #3
Foam filled is advertised to be as heavy as water filled.
   / Mahindra 4025 left Front rim broke in half #4
apparently, you need to take it much easier on the tractor, wheels should not be braking!.:shocked:
Thanks. I assumed foam would be really light. Good to know.
I did not know that. I have a lot to learn
   / Mahindra 4025 left Front rim broke in half #7
You have and pictures of this?
Good luck.
   / Mahindra 4025 left Front rim broke in half #8
Or the lugs were loose a little or it was a poorly made rim.
   / Mahindra 4025 left Front rim broke in half #9
From what I have seen and heard adding foam to tires does prevent flats.
It also reduces the cushioning effects that air provides.
On a smaller diameter front tire reducing the cushioning will definitely have the effect of transmitting more shock and side loading of the rims while hitting bumps and turning.
Years ago there were quite a few reports of front wheels separating when foam filled.
Most of those were on 2wd units and as I recall it was a consensus at the time that the foam was preventing the tires from flexing with turn loading which was increasing the wheel side loading and breaking wheels.
2016 Ver-Mac S/A Towable Trailer Message Board (A49461)
2016 Ver-Mac S/A...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
