mahindra 4025 2wd wheel noise under load
   / mahindra 4025 2wd wheel noise under load #1
cornisland99
jackson ms
mahindra 4025
I hear a clicking sound when my tractor gets under load. I just bought this tractor and don't know a lot about it. Please help. It only makes it when wheel stops turning under a load. Is this a problem or by design? Thanks in advance for your help.
   / mahindra 4025 2wd wheel noise under load #2
You definitely have a problem my 4025 doesn't do that.
When you say a load, do you mean the fel? Where is the noise coming from?
thanks Cowboyron for the reply! For example when i use my turning plow and it gets to deep. Tractor stops and one wheel just spins and other makes a clicking sound.
   / mahindra 4025 2wd wheel noise under load #4
Are you stepping on the pedal that engages the other wheel when this happens?
No, As soon as the tractor comes to a stop from the drag of the plow it starts popping noise coming from the wheel that is stopped. Seems if i remember the other wheel keeps turning.
   / mahindra 4025 2wd wheel noise under load #6
Sorry I can't help you with that.
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
Unused 2025 CFG QK20R Mini Excavator (A49461)
Unused 2025 CFG...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
FULL ACCESS TOOL BOX (A50854)
FULL ACCESS TOOL...
2001 FORD  F-250 (A50854)
2001 FORD F-250...
