Mahindra 3616 won't start
   / Mahindra 3616 won't start #1
Don the fitter
2013 Mahindra 3616
My tractor will only start if I jump the starter directly from the battery. I think it might be the starter relay but not sure where it is located. Not very good at this stuff but just need a little advice. Thanks in advance
   / Mahindra 3616 won't start #2
Not familiar with your particular machine, but the best place to start is to remove / clean / tighten all cables and wires in the start and cranking circuit... Including the main ground to the frame. Also load test the battery.
If you hear a momentary "click" when trying to start the tractor, the problem is very likely a high resistance connection somewhere.
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2015 Isuzu NPR 16' Box (A56858)
2015 Isuzu NPR 16'...
FORKS (A52709)
FORKS (A52709)
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
PALLET OF MISC (A58374)
PALLET OF MISC...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
