Mahindra 3616 Loader Joystick wont return from dump position
   / Mahindra 3616 Loader Joystick wont return from dump position #1
ELRUBIO
British Columbia
Mahindra 3616 Shuttle
Hi all...hope to find an answer here for my Loader problem. I was moving some logs thru some rough terain and after dumping my load the bucket would not return...the leaver stays in the far left position with no hydraulic pressure on the joystick or pump noise...i can move the leaver all the way to the right to move the the bucket to the dump position and can hear the pump going and relieving pressure and the joystick centers back on its own. The loader goes up and down normal so no issues with that. I wonder if i have a broken spring or spool valve? after researching it looks like i have a Cross SDV Loader Valve not sure if it is 10 or 15 gallon flow. Did anyone have the same problem? Thank you for your help..
   / Mahindra 3616 Loader Joystick wont return from dump position #2
I’m in the same boat, with your above statement. If you received an answer. Please help.
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
Unused 2025 CFG QK18R Mini Excavator (A50322)
Unused 2025 CFG...
