Mahindra 3550 vs LS XR4155 vs TYM T554
   / Mahindra 3550 vs LS XR4155 vs TYM T554 #1
4tillingdirt
nc
N/A
Which one you pick and why?
   / Mahindra 3550 vs LS XR4155 vs TYM T554 #2
LS.
I like the color blue.
Actual choice would depend on use and local dealer support. ;)
   / Mahindra 3550 vs LS XR4155 vs TYM T554 #3
Mahindra 3550. Heavy tractor, Mahindra built in India, No DPF, good dealer nearby, good pricing, great warranty, company has been around for 50+ years, one of the largest HP CUT's available with both power shuttle & HST transmission.
   / Mahindra 3550 vs LS XR4155 vs TYM T554 #4
Already picked an LS. It was $6,000 less than the nearest competitor with similar weight/hp and options. LS comes with 2 rear remotes. I was quoted $1800 for the second remote from Mahindra. Wayyy too much for adding a remote.
The higher prices support the dealerships and probably well worth it if your not handy with a wrench.
Oh, and I really like the Blue!
   / Mahindra 3550 vs LS XR4155 vs TYM T554 #5
I went with LS due to the included features at more competitive price. So far, it has been rock solid and I have not regretted the decision.
   / Mahindra 3550 vs LS XR4155 vs TYM T554 #6
I went with 3550 over LS. More tractor for about the same money. TYM was not an option for me.
   / Mahindra 3550 vs LS XR4155 vs TYM T554 #7
I too went with an LS the exact model your interested in. Great machine even though I did have a freak incident with my PTO wire shorting out on my clutch linkage this tractor has been great so far (42 hrs) plenty of power, quite, sips fuel and will wade through 5ft weeds with a 6ft bush hog and not bat an eye. Loaded the rear tires on mine and it has more then enough *** to get a full bucket of rock without feeling tippy. The biggest selling point for LS for me was the amount of tractor you get for a much less price then anyone else in the market and 5yr warranty.
   / Mahindra 3550 vs LS XR4155 vs TYM T554 #8
You would find that some Mahindra tractors are TYM so you could save more by buying them directly.
   / Mahindra 3550 vs LS XR4155 vs TYM T554 #9
Yes the new 25xx series are made by TYM for Mahindra. The 3550 is a different class tractor than the other two. It is much heavier thus HP to weight ratio is much lower compared to the other two. The Mahindra may not have a DPF but it does have a DOC and Mahindra has had some issues with the EGR's on the new MCRD engine design. I would choose the one that fits you best with the most reliable dealer.
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2006 Lexus ES 330 Sedan (A51694)
2006 Lexus ES 330...
40' CONTAINER (A51248)
WESSEX CHT-100R-E LOT IDENTIFIER 222 (A53084)
WESSEX CHT-100R-E...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
