Mahindra 3525
   / Mahindra 3525 #1
Wayne Weaver
Florida
mahindra 3525 w/ Loader
i have just purchased a mahindra 3525 that has about 470 hrs on it, second hand. I was working with it and it had been starting and running perfectly. I decided to turn off ignition and load wood into the bucket then rest awhile. When I went to turn on the tractor nothing happened, no clicking, no turning over of the engine, no lights on the dash, nothing.... made sure that all things were in neutral. still nothing , checked all the fuses on the panel under the steering wheel. bought a new battery still nothing ... does any one have any Ideas?
   / Mahindra 3525 #2
Make SURE everything is in "N". PTO, F and R, EVERYTHING. I've made the mistake only to find out I was in gear...
   / Mahindra 3525 #3
What is this national "NO Start Month" for the Mahindra's. Sounds like you blew a fuse since you have no lights or the battery connectors are bad. If it's like the 15 series you will have at least two 50amp fuses besides the other ones. Check them because that's the only thing besides cables that I see would kill the whole tractor and lights.
   / Mahindra 3525 #4
Something else you might try is your emergency lights to see if they work since from what I can tell it's independent of the ignition switch, at least on my 2815.
   / Mahindra 3525 #6
Wayne,
Do you have a diagram for the wiring on that tractor? I just walked out to the barn to check on my 3525 and the flashers should work without key. With the key turned on all other lights should work. I agree it's probably a ground wire.......but ??
If you don't have a diagram you can download them on the net or I would email you one.
   / Mahindra 3525 #7
Let us know what the problem is. I am thinking of purchasing the same tractor. Do you mind sharing how much you paid for your tractor and what came with it??
Dave in NC
   / Mahindra 3525 #8
Papasmith, I have a 3525 I bought through AgriCredit Auction for $9500 with 16 hrs on it. I now have 105 hours and love the tractor. I only bought the tractor, no FEL. I plan to add that later. I use it mainly for bush hogging. If you are in the market you should take a look at AgriCredits auction. They get some pretty good deals on newer tractors.
   / Mahindra 3525
Answer to Mahindra 3525 not starting: Fuse.........
As I stated, nothing happened electrical AT ALL....no lights, meters...etc.
This tractor is pretty smart (and I am glad for that), there is a relay swith control-combination on the lower left side (about a foot below and to the left of the steering wheel) that also houses the FAN FUSE: you will notice the little fan icon.
Apparently the tractor knows you are not smart enough to check everything and knows you don't want to buy a knew engine, so it blew this fuse to protect itself from overheating.
Consequently, this fuse coupled in that relay package tells everyone else on the planet electrical to do nothing.
The fuse is big, green in color (when not blown) and 30 amps.
Replaced the fuse....and away we went.
What caused it to blow? Only one thought: I being new to tractors forgot that diesel engines are like girls and need to be warmed-up (that is an exert from my wife)....I turned the switch and boom.
Last note:
Sorry for the lengthy reply, but it is informative for new people like me...I hope, and thanks to all of you posting to help.........Sergei, you were closest to the answer.
   / Mahindra 3525 #10
Not warming up the tractor doesn't seem to be a reason for that particular fuse to blow. Like you stated, the fuse is to prevent the tractor from overheating too much. I would make certain that the radiator and screen in front of the radiator are clean. They can get stopped up in a hurry under certain conditions. I would also make a quick check of your entire cooling system, fluids, good flow, etc. Also possible that the fuse was just about ready to blow before you got it and not due to anything you did.
Thanks, by the way, for providing your solution.
Dave in NC
2016 Quincy QSI-370i Rotary Screw Air Compressor (A42742)
2016 Quincy...
DOOSAN G25KW GENERATOR (A45046)
DOOSAN G25KW...
(3) VACUUM PUMP TANKS (A45046)
(3) VACUUM PUMP...
CFG Industrial TK35R Rubber Skid Steer (A44501)
CFG Industrial...
2015 EXA INDUSTRIAL PNEUMATIC TRAILER (A45333)
2015 EXA...
2012 CHEVROLET 3500HD PICKUP TRUCK (A43004)
2012 CHEVROLET...
