maizeandblue
I have a Mahindra 3525 i just procured. Looking to change the fluids. Book lists the following fluids and i have confirmed with Mahindra that if the book lists two different fluids that id be better off using two different fluids and i should stay away from UTF.
So for the transmission it lists API GL4 EP 90 (do not use GL5 because of brass or copper alloys used in tranny). Searching and searching for reasonable priced fluid and meets the specs was nearly impossible. First, most 80W90 gear oils state they meet GL5 which is where i have difficulty. Reading up on GL5 and GL4 from a guy who did a lot of research and then explained the difference in GL 4 and GL5 in a way most can follow. Now, any way i did locate a gear oil. However, it is a marine gear oil at Walmart "Quicksilver Premium Gear Lube 80W90" and it states that it meets GL4 specs.
I assume there is no difference in this gear oil and another brand not marketed as "Marine". I assume it is just marketed as "Marine" for the sake of marketing and there would be no difference in performance.
Are my assumptions valid? or should i be looking for one that states for heavy equipment, trucks, blah blah.
