xlr82v2
Platinum Member
- Joined
- Dec 3, 2004
- Messages
- 703
- Location
- Southwestern Illinois
- Tractor
- 2007 Mahindra 3525, 1952 Ford 8N
I finally got to do a good bit of 3PH work today with my new 3525, and it always seemed that when I would raise the hitch, the arms would want to spread outward. I thought that was kind of wierd, but didn't think too much about it.
When I took my lunch break, I got out the owners manual, and looked at the 3PH section, didn't really see anything that caught my attention, except that I learned that there are 2 pull pins that the lift arms can attach to, and that they should normally be attached to the upper set of pins. OK, cool, didn't think too much about it.
After I was done for today, and removing the bushhog, I noticed those 2 sets of pins. Pretty cool feature on this tractor, I thought. Yep, they're attached to the upper set of pins, just like they should be. Then I happened to notice that the sway bars were attached to the LOWER set of holes on the brackets. AAAHHH HAAA!!! That's why my 3PH seemed to be binding a bit and spreading out when I would lift it up!!! So, I moved the sway bars from the lower set of holes up to the upper set, to match the lift arms. Now, the geometry is all correct, and everything works smoothly, like it should.
So, make sure your sway bars are mounted in the correct holes. If your arms are on the upper pin, then your swaybars should be in the upper holes, and vise versa.
Mine came from the factory set up wrong, and if it happened on mine, I'm sure it happened on others out there also!! This could be what is causing the loosening of the sway bracket bolts which has been reported by others here on TBN. When you raise the 3PH with the sway bars in the wrong holes, it puts a LOT of stress on those brackets I could see mine flex!
Other than that, I'm 98% totally satisified with my 3525 so far...this thing is a beast!! With the bushhog, things that would kill my old 8N dead in it's tracks only makes the 3525 grunt a little bit
... I love it!!! With 10 hours on the clock, the only thing I really don't like so far is the location of the engine oil dipstick... with the FEL installed, that thing is a real #%$&% to get to. Actually, getting it out isn't so bad, but getting it back in is the hard part. Maybe I need to find an alternate route to snake my arm in there to get to it...
And don't sell the 25 series tractors short... they do just fine without 4WD when using the FEL!!
