MAHINDRA 3510 LOSING POWER
   / MAHINDRA 3510 LOSING POWER #1
kgholt
shutesbury ma
mahindra 3510
Last winter (very cold in the Northeast) I wasn't able to start the tractor. As the weather has become warmer, the tractor will start without a problem but if I run it for more than a couple of minutes it starts to lose power, it surges, and eventually stalls out. I've noticed that if I bleed it for a couple of minutes it will start and sometimes run for a bit longer but eventually comes back to the power loss-surge-stall routine. Any help is appreciated - I'm not a mechanic but I can follow directions! Thanks.
   / MAHINDRA 3510 LOSING POWER #2
Sounds like a fuel (injector pump, filter ,water in fuel or fuel restriction) issue to me. I would start with the water separator bowl and fuel filter then check the tank and fuel. If there was water in the fuel the injector pump could have rust and be sticking slightly , which might improve if you could get it to run a while. Hopefully an expert will chime in and help you with more ideas.
   / MAHINDRA 3510 LOSING POWER #3
My guess is fuel also, either filter problem or some other restriction.
   / MAHINDRA 3510 LOSING POWER #4
I would drain the tank and replace the filter. I would also use a good additive to prevent moisture buildup if the tractor isn't run on a regular basis.
Thanks all. Yep it was the fuel filter. It was leaking around the seal - maybe a faulty o-ring (I changed the filter and assembly last year). Anyway, I put the o-ring on from the old assembly. It isn't leaking now, and the tractor seems to be running fine. I checked all the fuel lines and tank and didn't see any other problem.
On another note, I've been using Diesel 911 - are there better additives that will prevent the fuel from gumming up in the winter? Is there some kind of receptacle on this model for putting on a heating block?
   / MAHINDRA 3510 LOSING POWER #6
My model doesn't offer a block heater - unless you're in an extreme environment you wouldn't need a heater - all brand name additives are good to go - nothing to be concerned about
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
6' 3pt Rotavator (A50121)
6' 3pt Rotavator...
2014 Ford F-150 Pickup Truck (A50323)
2014 Ford F-150...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2015 Ecoline 7 Ton T/A Equipment Trailer (A50323)
2015 Ecoline 7 Ton...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52748)
2022 Quick Attach...
