Mahindra 3510 engine popping noise
   / Mahindra 3510 engine popping noise #1
crackshot
case 222,allis chalmers wd45
I have a Mahindra 3510 3cyl, 34hp. After setting for a month we started it and it smokes out the exhaust and makes a loud popping noise near the back of the engine on the right side. It does quit smoking for a while the starts smoking again. Drained fuel and add 5 gal new with a fuel additive and ran it for about 2hrs. Still popping. 550 hrs. on engine. We did find a mouse nest in the area of the popping and cleaned it out. Oil ok, Air filter ok and radiator ok
   / Mahindra 3510 engine popping noise #2
The fuel pump is on the right rear-ish. I assume noise varies with the RPM?
Do you have an Engine stethoscope? Or if your me, a rubber hose and big nail.
TRUCKING INFO (A50775)
(1) 16ft Tarter Gate (A48837)
(1) 16ft Tarter...
2008 GMC C7500 CREW CAB FLATBED TRUCK (A50459)
2008 GMC C7500...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2011 Hyundai Tucson SUV (A48082)
2011 Hyundai...
PALLET OF MISC TILE FLOORING (A50460)
PALLET OF MISC...
