Mahindra 3510/4110 Rear 12Volt connector
   / Mahindra 3510/4110 Rear 12Volt connector #1
KENB
CENTERVILLE,TX
MAHINDRA 4110, Ford 2N
I think Willman asked this same question, but no responses, so here it goes again. The brochure for the 10 series mentions auxillary 12volt connector. I assume it is the connector in the rear that looks like a trailer connector. WHERE do you get a connector to fit that thing?? I guess you could get a meter and figure out where the power is and make your own connector. Anyone know about this rear 12volt connector???
   / Mahindra 3510/4110 Rear 12Volt connector #2
How many amps of power do you need? According to the wiring diagram in the back of the manual the top connector should be ground, the two on either side would be for taillights. The 5 o'clock and 7 o'clock positions are signal lights and the bottom one is for stop. I saw adapters online to go from a standard 7 pin male to this round 6 pin female . You might find something at an RV dealer. There is a spare on the circuit with the work light under the fender on the left side (I think thats where I saw it). I don't think that has a very high capacity fuse either. I also found a large (10 ga? maybe 12 ga?) hot wire near the back of the engine with a female push connector on it. I assume it was for an option I don't have. I took power from that for auxilary lighting and added an inline fuse.
   / Mahindra 3510/4110 Rear 12Volt connector #3
Thats where I pulled my power from also. The 12ga hot near the fuse panel. I played with the trailer plug and a meter for a while, then just pulled a wire front to back and put my 12V socket on it,
Mack Fire Truck (A50860)
Mack Fire Truck...
Fuel Tank (A50860)
Fuel Tank (A50860)
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
Air vents for roof (A50860)
Air vents for roof...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
Axle (A50860)
Axle (A50860)
