billw928
I have a 3505 Mahindra and never had any problems. This past fall after it had set unused for a couple months i got on it to
do some bushogging and when i pushed the pedal down to put it in gear the pedal would not retract. I was able to pull the pedal up by hand and it worked fine. Noticed it was hard to push down as well. I tried to grease the throw out bearing but found the fitting was clogged. Do you think the throwout bearing could cause the problem? I am going to replace the grease fitting and see if that is the problem. Just wondered if anyone else had a similar problem. Thanks
