Mowing Mahindra 3325 - 5 or 6 Ft. Rough Cut Mower?
   / Mahindra 3325 - 5 or 6 Ft. Rough Cut Mower? #1
glho1
I'm getting ready to purchase the 3325. All we'll really be doing with it is mowing 10-12 acres. Will this machine handle a 6 foot Rough Cut Mower, or is a 5 foot unit a better choice? Also, is there any benefit to the 3525 (and power steering) if I'm only cuttng grass?
   / Mahindra 3325 - 5 or 6 Ft. Rough Cut Mower? #2
It will run a 6' just fine. If the going gets real tough, just move over a few inches and cut 5' on your second pass.
If you get the 3525 you can add a loader later, and power-steering is almost always worth it.
   / Mahindra 3325 - 5 or 6 Ft. Rough Cut Mower? #3
I have the 3525 with FEL and love it. I mow around 14 acres with a 6 foot cutter. I've often wondered if it would pull a 7 foot cutter. The power steering is very handy. With the 6 foot cutter I usually cut in Low 4 and it makes for a good cut. It probably takes me 7 to 7.5 hours to bushhog it.
   / Mahindra 3325 - 5 or 6 Ft. Rough Cut Mower? #4
We actually mowed our orchard with a 3525 with a 8 foot flail mower and it did great. They sure seem to make more power than 35HP.
   / Mahindra 3325 - 5 or 6 Ft. Rough Cut Mower? #5
If a 3325 at 27 pto hp could run a 6 ft. cutter do you think a 4110 with 33 pto hp would run a 7 ft. mower in low brush?
   / Mahindra 3325 - 5 or 6 Ft. Rough Cut Mower? #6
I have a customer that does commercial cutting on a state contract and operates a 8' rotary cutter behind his 3525. I had told him an 8 footer was to much for the tractor so he bought the cutter from his local MF dealer. He tells me it works very well, and when the going gets tough the governer kicks in and the engine builds even more power. He operates the 8' cutter behind his 3525 and his 4110 and he is happy with both. I would go with the 6' cutter if I were you. Good Luck!
Galen LaWall
Your Mahindra Tractor Dealer
Batavia, NY
585-343-0770
John Deere 648R (A50121)
John Deere 648R...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
Craftsman LT2000 Riding Mower (A50121)
Craftsman LT2000...
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A50323)
2012 Peterbilt 337...
