mahindra 3016 adding remotes
   / mahindra 3016 adding remotes #1
ibkg
kenly,nc
Mahindra 3016
I have a mahindra 3016 and I would like to power my log splitter with it so I put a tee from the PB on the loader valve and also a tee from the out port on the loader valve ran the hoses to a couple QD and it will move the splitter ram in and out but it has no pressure to split the wood ......what could be the problem ? Thanks to anyone who can help
   / mahindra 3016 adding remotes #2
The tee's are the problem. Why do work when the oil can pass right through. Remove the tees. Reconnect the hose to the OUT PORT.Connect a hose to the PB port on you loader valve. This will be your supply for the splitter. The hose you removed from the PB port will be the return from the splitter. Note, when not connected to the splitter the PB hose must be reconnected to the PB port.
I posted this question over in the hydraulics section too might wanna see my thread over there i have some pics of what I have done in that thread I did away with the Tee in the PB line this morning and the splitter works my only hang up now is where to plum my original PB hose into so I can operate my 3pt hitch I would like to leave the remotes on permanently if possible and not have to switch hoses the hoses out all the time .. Thanks for you help
   / mahindra 3016 adding remotes #4
You may want to try setting it up like a PB for a back hoe. Run a hose from the PB port on the FEL valve to the rear of the tractor with a QC on it. Extend the hose that was connected to the PB port to the rear also and put a QC on it. You can hook up your splitter there. When not in use connect the 2 hoses together.
That looks like the best way to go .... Thanks alot for your help
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2017 DODGE RAM 3500 SERVICE TRUCK (A52472)
2017 DODGE RAM...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
