mahindra 2810 hydro
   / mahindra 2810 hydro #1
slowe350
Does anyone with a backhoe mounted on their 2810 hydro have any pictures of their sub frame they could post. Just bought a woods 7500 3 pt. and would like to build a sub frame thanks.
   / mahindra 2810 hydro #2
There are a number of Mahindra's with BK in the photo section.
MY 2810HST is there with a hoe on it , but I am not sure any photos I post for you will be any help as I have the Bradco 3375 Hoe that is sold by Mahindra.
Maybe someone has your hoe on one.....
Dave in NH.......
   / mahindra 2810 hydro #3
I've got the same subframe as dbelisle and a 3pt hoe. I've yet to start making the adapter to mate them, been using the hoe light duty as a 3pt mount. Long term plan is to make it work as subframe mount. The nice thing about the factory frame is the way it tucks up without reducing ground clearance as some do.
Priced a woods 4 pt mount today $1600 seems a bit pricey. Will check on bradco mount should not be to hard to convert to woods hoe. DO you have to remove your arms when mounting hoe. Thanks
   / mahindra 2810 hydro #5
The 3pt arms stay connected, just pull the pins on the check chains and let them hang.
2015 Buick LaCrosse Touring Sedan (A48082)
2015 Buick...
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A51039)
2017 Ram 5500...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
