Mahindra 2615 4WD
   / Mahindra 2615 4WD #1
Erniebo
Tracy, CA
Mahindra 2615 4WD
Just purchased a used Mahindra 2615 4WD "Yeah" need to change all fluids. Is there anything that's not in the manual I should know about?
   / Mahindra 2615 4WD #2
Welcome from VA
   / Mahindra 2615 4WD
Thanks,
   / Mahindra 2615 4WD #6
Welcome to TractorByNet!
We moved your thread to the Mahindra Owning & Operating forum. :)
   / Mahindra 2615 4WD #7
Great tractor, Erniebo. Welcome to the Mahindra forum. The only thing I can think of is when you go to change the fluid in the front axle, regular hydraulic fluid is now what is recommended.
If you have a loader on it, be sure to loc-tite and torque the bolts specified in the loader manual.
The 2615 went through a change in the glow-plug timer, (the old timer cycles for 3 seconds, the new one cycles for 10 sec.). That is how you will know if yours has been replaced. If you have the old style, it may eventually fail and you will have to replace the timer and the glow-plugs.
You will know when your timer and plugs are shot because starting will be difficult to impossible.
   / Mahindra 2615 4WD #8
Welcome from Alabama! I rely on the manual.
   / Mahindra 2615 4WD #9
Hmm I got a 2615 still ghat Manuel my pto stoped?
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
2014 AMERITRAIL, INC. TUGGER TRAILER (A50854)
2014 AMERITRAIL...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
