Mahindra 2555 O ring water sensor
   / Mahindra 2555 O ring water sensor #1
CharlesLW
Mahindra 2555
I have a leak at the O ring on the water sensor that attaches to the water separator/fuel filter. I have been unable to find a replacement O ring, I am told it does not come with a replacement filter, it is not offered separately, the only way to get one is to order a new sensor, which is $200+. Anyone know to purchase the just the O ring? or a work around? Thank you so much
   / Mahindra 2555 O ring water sensor #2
Take the O ring off and go to you local hydraulic shop, measure where it goes or take the sensor with you, get a kit of assorted O rings, visit Princess Auto/Harbour Freight, local auto supply store etc..............Mike
Thanks for the help. Took off the sensor yesterday, the dealer did not install the O ring when they changed the filter. I am not happy about that! I was informed by a different dealer the O ring was square, which I have learned to mean one side is flat, is there an image of these O rings somewhere so I can have something to work with? Thank you !
   / Mahindra 2555 O ring water sensor #4
Your very welcome, glad it helped.
.....the O ring was square, which I have learned to mean one side is flat,
Actually it's called a quad ring, most are like this with a rounded corner profile but there are some with completely square corners..........Mike
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2016 Nissan Pathfinder SUV (A53424)
2016 Nissan...
