sdoubledub
- Joined
- Feb 18, 2010
- Messages
- 25
- Location
- Gaylord
- Tractor
- Mahindra 2555 HSTC, old Kubota and ancient ford
I have a huge problem, and hopefully someone has experienced this, or heard about it. My tractor -
2015 with about 280 hrs, stopped going in reverse. The indicator light in the cab has "F" (forward) showing even though the pedal is in the regular position. In essence, it's overriding itself and assuming both pedals are being touched simultaneously, which makes the tractor not do anything. Has anyone experienced this? I checked under the cab, and both pedals appear to be properly connected to the spring mechanism. There are no loose wires that I see. Both L and R have 3 wires that appear to go into some solenoid of sorts. Both sides appear snug, and again no wires disconnected. This happened in the cold, while blowing / blading snow. Occurred approximately 10 hours after the dealer did the following:
Removed spring from throttle motor to achieve proper rpms,
Installed mid-pto kit and front mount snowblower
Also, the hydrostatic "sensitivity " button on the left appears to be detached (rocker just flops loosely). It's been like that since I got it used at 240 hours, but figured I'd mention it.
Thank you for any light you can shed on the problem,
Scott
Scott
