mahindra 2555 hooking up log splitter to rear remotes
   / mahindra 2555 hooking up log splitter to rear remotes #1
mikeman1
orange county,ny
mahindra 2555 hst
Hi, I have a 2555 with backhoe. When I have the hoe mounted I push the hydraulic remote handle on the side of seat all the way forward so the hydraulic fluid flows to the backhoe controls so i can use them. When the backhoe is mounted i always leave the handle forward even when just driving around. I assume its not deadheading and heating up the fluid. (I hope I am right)??.
I want to get a log splitter to work off those same ports when the hoe is detached. Is there a specific type of splitter I should look for so the hydraulic fluid doesn't heat up when I am just driving around with the splitter attached but not in use? If I understand correctly the 2555 is open center valves??? :confused2:
thanks for any help and knowledge.
Mike
   / mahindra 2555 hooking up log splitter to rear remotes #2
That set of ports typically can run a log splitter as it will be acting just like the BH in that the controls are move to the implement.
Most, after researching and seeing, realize the 3pt splitter isn’t that great. They cost about the same as a small engine splitter but lack the two stage pump. This equates to a very s l o w operation.....
   / mahindra 2555 hooking up log splitter to rear remotes #3
The same hoses going to my back hoe, also run my splitter. I don't mind the slow operation compared to a stand alone. The splitter runs plenty fast for me, and my needs. I really prefer the quietness compared with a stand alone unit.
Now, if I needed to split more than two or three cords a year, or had a commercial operation, I might need a faster machine. For now, slow and steady goes far in a day.
Thanks for the info. the search begins....hoping to buy one in the spring.
   / mahindra 2555 hooking up log splitter to rear remotes #5
Mike
Just make sure the valve on your logsplitter is an open center valve and you will have no problems.
great! thank you!
   / mahindra 2555 hooking up log splitter to rear remotes #7
Even with open center you should move your aux valve to the center when not using it...no sense sending oil through the splitter if you''re not using it and it will help prevent a major mess if you get a line caught on something and pull it off.
good point. thanks.
2004 GREAT DANE 53FT DRY VAN TRAILER (A52141)
2004 GREAT DANE...
2012 Ram 4500 Versalift EL29N 29FT Bucket Truck (A50323)
2012 Ram 4500...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52748)
Ditch Witch 6510A...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52748)
2015 Ottawa Yard...
John Deere 400 Rotary Hoe (A50514)
John Deere 400...
