MAHINDRA 2525 LEFT BRAKE LOCKUP
   / MAHINDRA 2525 LEFT BRAKE LOCKUP #1
JER2525
YELLVILLE, ARKANSAS
MAHINDRA 2525
When applying the brakes, the left brake locks immediately and locks the left rear tire. I have to rock the tractor in the opposite direction to get it to release. What is likely broken and how much cost and labor am I looking at to repair? Any ideas. I am currently waiting for my service manual to arrive. Thanks for any help.
Finally got to the brake problem. Both the brake discs and brake pads seemed to have a semi-dried but sort of sticky, I'll call it brake dust on them. Taking apart the spring loaded assembly revealed an excessively gummy greasy mess that sort of caused the three balls to stick in their graduated slots. I cleaned this assembly and with only an extremely thin coating of hi temp brake grease, assembled it back together. I cleaned the metal brake surfaces with a soft wire wheel and wiped them down with MEK. I did the same to the disc pads. Long story short, the brake works fine now. Disassembly and assembly was relatively easy (not a bad design), The only special tool was a spring remover and installer.
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2017 JOHN DEERE  30G (A50854)
2017 JOHN DEERE...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2013 F-550 Bucket Truck (A51039)
2013 F-550 Bucket...
