Mahindra 2516 Gear Fuel Pump
   / Mahindra 2516 Gear Fuel Pump #1
KingBubba
Brooksville, Fl
Mahindra 3025 Gear
My fuel pump bit the dust over the last 2 weeks or so. I cut the field 2 days ago and all was fine following the fuel pump stuttering a few days before that. Today I started, as normal, after the pump brought me up to pressure. I backed up about 20 feet and the motor died and would not restart. The normal clickety click of the pump was and still is missing after the stall. I am assuming I need a new pump. I can find no schematics for Mahindra anywhere online. I do know that it is in the compartment under the dash which also puts it under the tank. I checked the filter and when it was pulled there was a nice flow of fuel; so the issue is not fuel flow or quality as it was clean and free of water.
Does anyone know where a parts diagram might be online? Has anyone had any experience with the Mahindras and their fuel pump replacements? Any info would be greatly appreciated. Many thanks.
Searching about a new fuel pump for my Mahindra 25hp was a real eye opener for sure. The Mahindra parts depot wanted $143 for the pump. Another tractor parts supplier wanted $248 for the pump. Yet another depot for forklifts and the like wanted $558 for the pump.
At this point I smell a great big rat. I do a search on Ebay and after a good search, I found the same pump from California for $13.29 and another from New York for $13.59. I took a chance and bought one from each dealer. There were also about 100 Chinese dealers with the same part for less than $20.
Today I removed the old pump and installed the new one. The wiring plug was even the same configuration. After a painless install I fired up the tractor and it was perfect. The pump was even quieter than the original. This just goes to show what a little research can do. Don't let the bastards drag you down.
2014 Ford Escape (A51694)
2014 Ford Escape...
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
1985 Ford Ltl9000 Tender Truck (A53472)
1985 Ford Ltl9000...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
