Mahindra 2415 will not start
   / Mahindra 2415 will not start #1
peparker1
Mahindra 2415
I am having the hardest time getting my Mahindra 2415 to start. I was in the process of mowing in some pretty heavy brush when the tractor stalled. I was able to reset the PTO safety switch (pin was broken) and the tractor started up. I moved it back to my lay-down area and replaced the PTO switch. It no longer will start. I have tried everything that I have read regarding the electrical connections. I even tried to short the starter terminals, the first attempt the starter engaged and cranked the engine briefly. I tried again today and only the bendix spun. I really could use some help.
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2011 Kubota M7040SUD 68HP Utility Loader Tractor (A49461)
2011 Kubota...
2012 MAGNUM TRAILER (A50854)
2012 MAGNUM...
AC CHARGING MACHINE (A50854)
AC CHARGING...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
