Mahindra 2015 won't start
   / Mahindra 2015 won't start #1
Hucksun
Monson, MA
Mahindra 2015
My 2015 Mahindra tractor won't start. It has a new battery which allowed it to start 4 or 5 times before it died again. I have cleaned the battery terminals including the ground terminal where it connects to the body of the tractor. What should I try next?
   / Mahindra 2015 won't start #2
Is the battery still charged? Or is the new battery dying?
Could the altinater be malfunctioning?
   / Mahindra 2015 won't start #3
If you have the headlights on when you try the starter, do they dim considerably? If so, either battery is bad or cable connections still not tight. Keep trying.
Jim
New battery is 12.5 but started at 14.5
No headlights at all no lights at the instrument panel no click nothing.
   / Mahindra 2015 won't start #6
Might be worth a battery test at the parts store. But how many hours and years old is this machine? Seems like a charging problem if you replaced the battery, then the new one only lasted a few starts. Any accessories normally on that use a lot of juice?
12.5 is not good but should run lights, etc. New batt might be bad, or re-check all connections. Maybe you have a cable with an internal open? Just fishing here...
Jim
Jim
Thanks to all who responded. It was indeed the cable and after much more tightening than I thought would be necessary the tractor is running like a charm.
2017 Ford F-250 Knapheide Service Truck (A48081)
2017 Ford F-250...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
5th Wheel Dolly (A49461)
5th Wheel Dolly...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2025 K1428 UNUSED Traffic Cones (A50860)
2025 K1428 UNUSED...
