Mahindra 1640 slow dump
/ Mahindra 1640 slow dump #1
nosaint
Mahindra 1640
Are the curl and dump functions supposed to be the same rate? (new to tractors). Thanks.
/ Mahindra 1640 slow dump #2
A common problem is a quick disconnect becomes partially connected causing slow cylinder movement. Try lowering the loader to the ground, turn tractor off, move joystick in all directions to release any trapped pressure. Then uncouple and reconnect each quick disconnect for the curl dump circuit.
By design Cylinders will retract faster than they extend under normal operation. Depending on valve design on your tractor it may have option of regenerative “fast” dump so will dump significantly faster than curl.
2017 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2017 Volvo VNL T/A...
L6060 Kubota For Sale
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
2022 EZ-GO ELITE...
