Mahindar 4510 instrument cluster removal
   / Mahindar 4510 instrument cluster removal #1
yanmars
Veteran Member
I want to replace the starter switch on the 4510. I removed two phillip head screws on the dash and the gauge cluster almost releases and pulls out to give me access but the top of the cluster will not release. I cannot see what is holding it in place. Anyone have any experience or ideas on the same. Unable to get the switch replaced if I cannot get at it. Thanks
Actually the problem turned out to be a bad battery cable. Not dirty or corrosion or a bad ground.
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
1043 (A50459)
1043 (A50459)
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
2007 Pace American Enclosed Trailer (A49461)
2007 Pace American...
2018 Ford F450 (A49461)
2018 Ford F450...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
